power effieceny of amplifiers
Efficiency = Power Made/Power Drawn ...
So if an amplifier makes 1000 watts draws 2000 watts, it would only be 50% efficient ...
Class D amps are 65-85% efficient at full output (and a little less efficient at less than full output).
Class T amps are 60-80% efficient at full output (and a little less efficient at less than full output.) from what I've heard.
Class A/B amps are about 45-65% efficient at full output, but much less efficient at less than full output.
Class A amps are 40-60% efficient at full output, but even less efficient at less than full output.
Class A is usually alot less efficient than 40%
Here is TRU's class A for example
http://www.trutechnology.com/a_class.htm
Efficiency (Class A): 15% @ 4 Ohm RMS
??? I believe they have a maximum of 25% efficiency, and they draw full power at all times because the outputs are always "on". That's why you hardly ever see more than a 25w per channel "true" class A amp, they are **** power hogs.
originally posted by werewolf at this link
If I may ... Pure Class A operation requires that the current pulled from the supply does not change as the load, or signal delivered to the load, changes. So a measure of the no-load idle current is a perfectly valid indicator of how much "Class A" power the amp can deliver.
Theoretical, ideal efficiency of Class A is indeed 25%, as thor indicated. BUT, that's for "single-ended" power delivery. A differential or balanced power delivery, where both ends of the load are driven with anti-phase signals, can do better. How much? Well, you will get twice the VOLTAGE to the load, but have to burn twice the POWER to do it. Exercise left to the reader
Werewolf is a very, very smart individual and I don't doubt a word that comes off of his hands (typing). So take the above for what it's worth
Now, either Soundstream's amps weren't pure class A like they claim they were or they're more than 25% efficient ...
The A 3.0 & 6.0 weren't true class A's..........
Most companies that claim to have "class A" amps are really just high bias class A/B amps. As noted in the quote from werewolf, idle current draw will tell you the amount of class A power available (since the outputs are on all the time, it will pull full power with no input).
Dragonknell
Computers B4 I Could Read
Dragonknell
Detroit
squeak9798
