possible to run bx1500d below one ohm?
Everything I read about this particular amp was that it's misrated at anything ABOVE 1 ohm, and that "If you're going to use it, use it at 1 ohm"
Also apparently the manual differs from the box which differs from the website which differs from what the techs say, when it comes to 4 and 2 ohm ratings; but 1 ohm remains the same;
is there anything i can do? to make it run lower...cause i was thinking about putting 3 hx2s in my car sometime...i dunno an ideabut is itpossible or is it just plain crazy...
Mike
i thought you were goin with those mtx 10's changed your mind again?, and no its not really doable
uhhh, i've been running mine at a .75 ohm load for about 2 months now, no problems whatsoever. i dont see where yall are getting ur information from, other than the fact that hifonics is sort of frowned upon by some ppl on this forum.
Impedence will rise once the subs are in the box, will vary with frequency and will rise as the VC gets hotter (along with other variables). You may just be "lucky" because your amp rarily sees below 1ohm. But generally I would advise against trying it.
i'm getting my info from personal experience
nikosbuddy
I pooped a hammer
nikosbuddy
In louisville
iceteebone
