positive battery terminal thingy
the fuses are on this little box thingy that is attached via the battery terminal by the standard ring nut/bolt setup... could i use a two-way power distribution terminal top and just run that box thing into one port, and my amp wiring into the other?
Originally posted by darkimportgrey the fuses are on this little box thingy that is attached via the battery terminal by the standard ring nut/bolt setup... could i use a two-way power distribution terminal top and just run that box thing into one port, and my amp wiring into the other?
you mean after market battery terminals?? yea If the fuse box has a wire that goes to the clamp
darkimportgrey
SQ *****
darkimportgrey
Boise, ID, USA
chris229
