Ports vs. Sealed specific to a convertible (sq).
Barjam
For a convertible, wouldn't a ported box (in theory) have a better response curve than a sealed box?
If you look at the response curve of a sealed sub there is a nice gradual dropoff at 60ish hz or so. In theory cabin gain (in a normal car) would replace that curve with a +12db gain so everything would EQ (very roughly) to a nice flat response. Obviously I am oversimplifiying this a great deal.
In a convertible you don't get cabin gain, so to get a nice flat response you would need to EQ a sealed sub more than a ported.
Does that theory sound about right?
the best I can describe a loading board from the picture I have seen is a flat piece of wood mounted a few inches above the subs as wide as the box . this pressurized the subs so the sound wouldnt just go right out the convertible.
these methods pressurize the subs, a ported box wont,even though they are louder.
I really have no idea what you are trying to say there //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif, but 'front loading' the sub really is irrelevant to the enclosure type, other than bandpass where the sub is completely enclosed in the box making front loading impossible. You can front load in a sealed or ported application, it makes no difference.
Front loading is a method of placing a rigid and reflective surface a relatively close distance from your speaker to create a pressure area in front of the cone. In my experience it helps 'contain' the bass inside a convertible vehicle. Down-firing is another method of front loading, but down-firing tends to transfer more energy to the vehicle's chassis (a good thing) than does a side-mounted loading board.
Barjam
Barjam
Olathe, KS
loud-n-low
