porting threw the rear deck
Yes. Well thats my 2 cents. I have never done it. But for SPL and just having the tunes come into the cabin area yes its worth it. If you seat does not fold down. Its a good way of getting the Freq. to enter in the cabin area.
i kow a lot of peoploe on here just seal there trunk and have the subs and port fire into the cabin. so id say yeah it has to be worth it.
well im looking at a crown vic and from what understand the rear deck is HUGE in those so running 2-6" or 2-8" ports shouldn't be a problem, but alot of people still stick with the old sub back port back so im curious on the difference
I've only heard one setup locally slot ported through the rear deck(2 12s, 2.5kw).. I remember hearing it before(subs/port back) and it was significantly louder, also just all around sounded clearer and less muffled. Obviously moved a shit ton more air than the old box setup did too.
But if u can sealed it off from the trunk and fire the woofers/ports in the cabin with the seats folded/removed it will the loudest in trunk setup you can do.
Hummm. An Ignorant statment to say. But I guess I have to explain. No I have never done it with any of my systems. But I have helped others do it and always suggest it when going to comps and see ppl who do not do well with a trunk system when they cant fold their seats down and dont wanna rip their seats out. I guess blind ppl like yourself missed the rest of what I said. females do that often. Only hear what they wanna hear or I guess in this case read.
JUST Porting into the car can lead to cancellation issues. Unless you're sealing off the trunk and assumingly firing into cabin, I wouldnt' recommend it.
If you want to port into the car, do a bandpass box.
Only thing really to do is to try it and see what happens. Mostly everything is done by test and retest. If you going to do it. Cut that baby all the way out. I know the crown vic and yes it does have a big deck so why not just cut it all the way out. Understanding you will be leaving important parts in. Unless you wanna lose your back seats like everyone is telling you to do. Are you going for any world records. Loudest in the state.
ehhhhhhhh i feel there is a major loss in output in mine. it's very car variable though. my car is ok with the setup but i know it's not optimal.
WOW, definitely not the remark I expected to see after all the time you spent on that installation on the build log or by the videos you posted of the setup after it was nearly completed. Thought for sure I'd see a //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif.
Explanation would have helped in the first place, you stated that you have never done it, but you think it's a good idea. that's it. If you don't have any experience with it, you really have no business giving advice.
You must be blind son. Or have no reading comprehension skills. If you did both of those statments would Imply I have some kindof experience in it.
spencer321
spencer321
palm bay
Crownvicon28s
