Ported Problems....Hollow sound....
Cameron_B
Single Cab Loud
I have a ported box 3.0~ at 32hz....2 RE SE and im get a "hollow" sound and loss of pressure at certain frequencies.
It's like its not got back pressure on the cone....almost like its free air....
I have the SSF set at around 30.... I thought it was bottoming out...
For instance on TI-top let back
the first line of notes
Dum da dum dum da da (hollow) dum (full sounding)
Maybe it's playing out of its range 100hz+......?
What I can tell you is that in my sealed enclosure for the same subs
it hit all notes in the song almost equally....
sealed it was around 1.3 each...
Another example is the "bumps" at the begining of the song it misses, but the bass line it slams.
Maybe its because im used to running sealed all this time, and am just not used to shallow "hits" and wide lines.
Your box may have a nasty/peaky response, or your LPF is set up high and it's playing mid notes, which will result it in sounding like shit //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And honestly, I LOL'd at :
Sad part is I'm pretty sure I can understand how you mean it sounds, haha.
sounds like you ported to low. do you have specs on your box?
Ported too high would be a more logical solution. If you're peaking the system in the 40s, your rolloff will cause you to not have any damping on the back of the cone at lower frequencies.
Alright Ive narrowed it down my taking a ride XD I am 75% sure I have the lpf set to high....these SE's must have horrible 75hz+response....they are monsters around 40hz though.
Cameron_B
Single Cab Loud
Cameron_B
NC
Cameron_B
