Ported Box vs. Bigger Amp
xluben
I have 2, 12" Assassin's in 1.25 ft^3 sealed (each). They're getting powered by a Profile AP1000M which says it puts out 500W RMS x 1 @ 2 ohms, but I've never seen a bench test for it posted online, so I'm not sure what it actually puts out.
I'd like to know if I'll get louder by going with a ported box (~3.5 ft^3 combined, tuned to 32Hz) or more power (~800W)?
WinISD shows both upgrades getting just about as loud (slight edge to the ported box), but the ported box plays quite a bit lower, and the ported box woud cost me a lot less, but it will take up nearly my whole trunk.
What do you think should be my first upgrade: ported box or bigger amp?
Also do you think SQ would decrease with a ported box?
Either way your going to want to do both, start with the cheapest/easiest.
yeah, and then once i do both, i'll probably want something else...........
the ported box is definitely cheaper, so that might be my first upgrade.
What is it you are looking for??? If its more SQ, I would get the bigger amp, and a better brand of amp. If you just want BOOOOOOOOM, slot port the subs.
Personally, I would stay sealed, and get a nice JL, Kicker, RF, Alpine, Phoenix gold etc. type......800watt amp.
I like the SQ that I'm getting now, but I want them louder. I also wouldn't mind getting more body shaking (deep bass), so I think I might have to try a ported box. I'm sure that a new amp down the line will add even more thump. Here's the plan I'm probably going to end up using (3.5 ft^3 @ 32 Hz):
It models very close to Ascendant's recommended 4 ft^3 at 32 Hz, and should be louder and deeper than 800W sealed, but I lose a lot of my trunk //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Screw it dude....I would port them first. With my 8s, I have had both setups within a month lol. I didnt lose to much SQ when I went vented. A little peaky in some songs and it doesnt blend as well. Some EQing can change that. The tradeoff was definately worth it. The lows are fun //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
xluben
xluben
Minneapolis, MN
Fast1one
