Rashaddd
Terrrrrist
Are you saying the bass is too loud? Turn it down.the bass sounds too high. bass boost-5/18
gain-.5/2
lpf-50
gain-.5/2
lpf-50
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif the subs do nothing but reproduce the signal you give them...the box can't make it sound like higher frequencies unless the box is resonating like hell I suppose, which i highly doubt.no. the bass does not sound low. they sound high. the amp is mono amp so there is no hpf, so thats not the prob.im goign to fix my gain tomorrow. gettin rain like crazy.
turn the bass boost down, turn the lpf to 70, and turn the gain up until it sounds like it is at full volume, then back off it a bit.the bass sounds too high. bass boost-5/18
gain-.5/2
lpf-50
ahh. i thought the tuning affecting the frequencies.//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif the subs do nothing but reproduce the signal you give them...the box can't make it sound like higher frequencies unless the box is resonating like hell I suppose, which i highly doubt.
You're right about the effects of the sub on tuning frequency and that the sub plays no role in altering it but that the sub will play a role in the alignment of the sub/enclosure system. However, in a ported system, the back wave never comes out of the port. What you're describing is actually a horn where the back wave is delayed linearly along the line and can will be in phase at the tuning point of the horn. In a ported box, the mass of air in the port moves back and forth like a passive radiator would and it moves the most around the resonance. That frequency where the port is most excited is the tuning frequency. The port can be in phase with the driver but more than likely it will not be anywhere near in phase.A box has a tuning frequency, which is basically the frequency where the back wave from the sub is most perfectly being inversed and coming out in phase with the front wave of the sub.
//content.invisioncic.com/y282845/emoticons/handclap.gif.0c301076f534e244f0460706894f19e0.gif dummyso you're telling me that the 0-80hz can hurt your ears?
if i was gay and sigged cool statements, this would be it good job koveman the **** up . if it hurts your ears thats a good thing , thats like complainin for a girl having a huge *** or tits
