RAM_Designs
SketchUp Master
I'd go with a slot port since a pair of 6" aeros are going to need to be 29" long each in order to get a 28hz tuning in a 6ft^3 net box.
13" each, but that won't be enough port area for three 12" subs. The minimum I would do is three 4" aeros, 19" long each.Okay do you know how long 2 4" ports would need to be to get a 28hz tuning?
Because the typical 5.25"-6.5" coaxial/component set can't play down to 60hz with any real authority.why would you want your subs playing up in the 60hz range for daily anyway?
thats why you dont settle for typical componentsBecause the typical 5.25"-6.5" coaxial/component set can't play down to 60hz with any real authority.
There aren't many 6.5" mids that can actually work in a 2-way and can produce a generous amount of midbass...but then again, I like a lot of midbass. What do you run? And what do you have your sub/components crossed at? I'd bet you'd be surprised how high your sub plays, no matter how low you have it crossed.thats why you dont settle for typical components
Yes, adding a third port will give you more radiating surface area, so you'll have the potential to be louder. Just remember that you need to adjust the length of the other two as well and not just add a third of the same length. Maybe tune a little bit higher, like 30hz, and see if that helps your upper-end response. Either that, or shrink the box size down a little.Still wondering about the port question...thanks for the help guys
I can see that I suppose. I forget not everyone goes all out when they do an install lolBecause the typical 5.25"-6.5" coaxial/component set can't play down to 60hz with any real authority.
