Port size
  • 2
Generally having a port that is a bit too big won't hurt anything. Larger ports are more efficient at higher output levels and at worst case it's a bit overkill and will make the box be larger than needed to fit it. If it's no issue to fit the box/port either way, I'd do the 3 or even just do a 2.5. You won't lose anything by going bigger.
Thanks:cool: a 2" port needs to be 4" long or a 3" needs to be just over 10" long for a 33Hz if i've got my maths right. I've made a very rough box & have use a 3" cardboard tube for the port to test out which way to have the sub & port ie facing the rear door or facing up or even across the boot sorry trunk before I build the real enclosure. Have had a sealed box for years which sounded ok but wasn't really happy with it as I wanted more from this sub
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
826
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
977
sweety
sweety
Northumberland, UK
sweety
