Port size
Generally having a port that is a bit too big won't hurt anything. Larger ports are more efficient at higher output levels and at worst case it's a bit overkill and will make the box be larger than needed to fit it. If it's no issue to fit the box/port either way, I'd do the 3 or even just do a 2.5. You won't lose anything by going bigger.
Thanks:cool: a 2" port needs to be 4" long or a 3" needs to be just over 10" long for a 33Hz if i've got my maths right. I've made a very rough box & have use a 3" cardboard tube for the port to test out which way to have the sub & port ie facing the rear door or facing up or even across the boot sorry trunk before I build the real enclosure. Have had a sealed box for years which sounded ok but wasn't really happy with it as I wanted more from this sub
sweety
sweety
Northumberland, UK
sweety
