POrt question
osix
I need a 6 inch port which is 12 inch in length .
but the Box i have would only have 15 inch from the depth i cutted the 6 inch hole .
i got a question .
if i want ot use a Round Port .
Can i Bend the Round port to create the length i need ?
i was thinking .. a 6 inch diameter port - which is only 8 inch .
and then i add 2 more port beside it which is only 2 inches in diameter ?
is this allow , anyone have any idea or suggestion .
Thanks you .
i hope i make the question clear enough if you have question for my question please feel free to ask
i was reading the mach of about 0.10 which i think is better with less noise .
the hole drilled is 6 inches . - that is why i am asking this question . a smaller port would give me a shorter length .
just seeing also if anyone have good idea if i insist on having the 6 inch diameter round port -
will bending it be a good idea ?
i am tuning at 35 hz .
if i shorten it i must tune it at 40-43 hz .
bending is a lot better idea then two additional pipes or whatever you were talking about.... bending should be fine.....
did you calculate the displacement of the port before !?!? j/w
osix
osix
Asia
swimfreak26
