port noise coming from one port.
flakko
Veteran (my butt)
10,845
So Cal
ive got 2 ports on the side right side of my box, and theres only noise comin from the top port not the bottom... do i have too little port area? they are 3" flared and i have a 12" RLP
edit: 16" long each
cha i did...there isnt any air leaks around the mounting thingie. i can check again tomorrow... but i find it wierd that its comin only from the top port.
aero>slot, I'd also say 4" if possible
dang..... now i gotta mod my box... the 3" ports barely fit on there.
its 9" thick.
could it also be that the pole vent of the sub is only 1" away from the wall of the box?
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
863
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
flakko
Veteran (my butt)
flakko
So Cal
SAG3
