port noise... advice?
psych0ticnemes1
Psych0tic Customs
2.5 cubes tuned to 32 with 29^2 of port....
My port makes a bit of a ruffling noise when i play low tones and such... (moving a lot of air...)
isn't 29^2 enough port area for one little 12?
YES it IS particle board!!! cheaper, this is just a test box... (besides... works well for me....)
Thanks guys..
Flare the opening of the vent, a 1/2'' round over router bit will do the job nicely.
Also make sure the sub and box are properly sealed, a vented enclosure at tuning is under more pressure than a sealed one at the same frequency.
Thanks guys..
since it's just a test box, make another w/more port area.
cool, i've gotta cruise over to the shop that's building my box cause he doesn't have a stencil for my speakers, i'll be sure to ask him about that
port's horizontal along the bottom of the box, tho, firing toward the rear, i don't know how he'd do a corner, it'd probably be right underneath the subs
You meant a corner in the port? No it does not always need a bend in the port. Only when the box is deeper than the port. Then you make it L shape. I was talking about corner angles. To reduce port noise...
Straight is fine.
psych0ticnemes1
Psych0tic Customs
psych0ticnemes1
Behind You
tRiGgEr
NorthFramingham
    Jun 30, 2026
