port locations
yeah I can only use the top 8" box rear for port area and subs come down a little over 7" so need to put ports in between them or something.
I'm also worried if I do it that way with short port length the Sub being right next to opening of port might cause a problem.
yeah thats what I was thinking also.
Has anyone ever angled the ports? So they aren't at a 90* in the box.
I was looking to do aero so I can swap them out for comps
Otherwise A slot port would work. Run down back wall and across bottom, with exit 8" below top
U will need two 6" ports as two 4" will only provide you with about 5.5 per cube. Which even with aeros is too little port area.
2 6's for 2 12 type R's? No way... A 6" is plenty. You don't need as many sq inches of port per cube than a regular slot port...
KRYPTO
KRYPTO
MN
bassman3
