port help?
  • 2
I'm designing a center ported box but there will have to be bends in it as of right now the inner port dimensions are 3 high by 7.75 wide. When I get to the back of the box where the turn has to be do you half the port height to make it 1.5 at the back and go both left and right and do you half the remaining length and go wither way?? Any help is appreciated
I'd have the internal port end 7" away from the back wall and just roundover that corner. That back (rounded) wall should effectively extend the...
None so far, there was a factory 8 inch subwoofer that I took out for a pass through, I'm definitely going to have to get some sound deadening...
10
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
909
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
631
67bass71
67bass71
Lake City, FL
PSturmer
SlugButter
    May 4, 2024
slater
    May 2, 2024
