Port formula by hand!? got problems...
  • 4
ngsm13
BSEE
41,527
Cincinnati, OH
Hey, so using the formula @ JL:
http://www.jlaudio.com/tutorials/ports/index.html
I solved for Lv, and got some whacky number (like in the millions). Maybe i'm a retard...but...i need help.
Fb= 32hz
Av=70 (14x5)
Vb=7.25 cubic feet
So, what am i doing wrong, any help would be appreciated! I want to see the exact length i'd need.
Also, the current design i have is:
Av= 70
Vb= 7.25 cunic feet
Lv=18
What's the exact tuning (by hand, i don't trust winisd or ****).
Thanks for any help provided...i'm going to continue to attempt figuring this out. peace
NG
Convert box volume into cubic inches...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
OOOOOHHHHHHH! fer shizzle...so... 7.25 cubic feet would be...
7.25*1728=12528 correct?
peace
NG
Ahhh, deletion !
yeah, uncalled for, but so are someother posts //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
WOW! 30.5 that is extremely off what i designed in WinISD.
Any help on this?
Av= 70
Vb= 7.25 cunic feet
Lv=18
Thanx, peace
NG
Ok OLDSCHOOL, i realllllly appreciate it! I got flustered....and rushed...and went ahead with an 18" long port. So tuning should only be slightly higher. Thanks you a lot oldschool! peace
NG
yeah man your only talking like a 1/2 inch if your using winisd pri with the update it's pretty close
where alot people go wrong is when they try to figure out a second port wall on a L shape length and displacment
true! that's why i did it this way...i didn't want to do an L-shape port...that is the largest port area i could do and still keep it straight! peace
NG
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
991
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
690
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
857
831
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
ngsm13
BSEE
ngsm13
Cincinnati, OH
ngsm13
    May 12, 2024
Brendon Jenness
    May 11, 2024
