jco1385
expert jcologist
cola is for fegs. real niqquahz drank grape drank //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
i plan on it sometime soon.i would still upgrade the power wire to at least 4awg.yes,it does make a difference in the sound,may not be much,but it does make a difference at least im my installs.
yea i hear ya,my o gauge american bass wire was alot easier to play with than that 4 gauge from scoshe i use to have,very flexiable wire //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifi plan on it sometime soon.
for now im just trying to get everything to at least work, and i want to get the subs well broken in before i upgrade wire, hopefully in a few weeks i can run some 4gauge. the 1/0 i have is stiffer than a mother.. so bending it a lot in a truck would just be a pain in my ***.
Sounds like you are just pulling more than 30A of current. What are the fuses in the amp rated for?ok, im bumping this because i still have the problem..
When i play a song almost all the way up after about 10 seconds pop, blows the fuse..
i have a really good ground, is it i might be clipping the amp? i havent set the gains with a DMM just set them to what i thought was a safe level (ie not clipping)
i still have 8 gauge wire and the wire that connects to the batt is 8 gauge then about 3 inches later its crimped with really small yellow wire with a 30A fuse than it goes back to the 8 gauge.
if i upgraded to 1/0 and a 200A fuse would this solve the problem? because i really dont want to replace 200A fuses..
This is what the fuse i have on it looks like (same one)
