poor amp
jellyfish420
i design boxes .......
this my friends is what happens when you mount an amp w/ the rca's too close to the floor //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i haven't decided yet if i'm gonna steal the rca jacks from the output and move them over, or if i'm just gonna put some female rca cable's in there and run them out the holes. if i do the second i'd feel much safer cause i wouldn't have to pull the board out...
If the amp was securely mounted however close to the floor it was I'm not understanding how this happened?
Sucks nonetheless, though. Nice amp...or at least it was/will be again eventually...
it was securely mounted...about 1/2" off the floor. the rca jack itself was touching the floor. i guess vibrations got the best of me
probally had amp laying around unmounted....RCA's jerked connector out of the amp....
i don't trust anyone around here, EVERYTHING is securely mounted //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I am with Prowler on that one. Hard to see how the RCA jacks could be too close to the floor causing that. Unless it was mounted on a vertical surface very near the floor with the connections pointing down. If it was mounted flat on the floor is it possible that someone stepped on them?
it is mounted vertical, and all the connections on my amp come out the bottom. i'm fixing it tonite and putting it back in my car. when i get it back in i'll take a pic so you can see how it is mounted. (keep in mind i've already raised it up about an inch or so)
jellyfish420
jellyfish420
STL ill side
jellyfish420
