Polyfill still a good idea?
maylar
Electrical Weenie
It seems that conventional wisdom and standard practices have changed over the years, and I'm wondering if adding some polyfill to a sub enclosure is still common practice, or if it's been deemed a waste of time.
So, for you box builders... use polyfill all the time, never, special occasions? What say you?
Thanks
Probably more of a personal preference then anything. I used it in my HT sub build just because it was a pretty small enclosure and I wanted to try and get some better low end. I say just try it both ways and go with the way that sounds the best to you. It's not like it's costly or difficult to install/remove.
There's more Physics than Tricks involved. The sub doesn't "see" a larger enclosure. The idea is to absorb air pressure so the subwoofer is not disturbed and can then move correctly (the way it was designed to move) when signals are sent to it. That's why audio drivers are tested in acoustic chambers - so standing/reflecting waves interrupt the movement of the driver as little as possible.
maylar
Electrical Weenie
maylar
Connecticut
neonblack
