POLL: Box Designers...who accounts for wood thickness
Do you use external dims when calculating?
  • yes, i use external dims when calculating the cu. ft of my boxes
    Votes: 4 15.4%
  • no, i take 1.5" off of every dimension when calculating the cu. ft. of my boxes
    Votes: 22 84.6%
  • Total voters
    26
snb778
blaugh!!!!
When you guys are calculating the Cu.Ft. of a box, don't most of you guys use the external dimensions when you say,"the box should be 8cu. ft." or, "my box is 10cu. ft.) and also do most of you use the external dims when calculating port??
from what i have seen this is the case, but if not, then that explains a lot for my experiences, and i have much to learn, for all of my box designs, I use the external dims when i give out my box sizes.
umm... I account for it //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
It depends whether you are talking about gross vs. net dimensions
just if someone says, "how many cu. ft. is your box" wouuld you tell them the outer dimension size, or the inner dimension size?
cause when i have posted the dimensions and size of a box for a sub... nobody has EVERY caught it and been like, "hey, you said you need 6 cu. ft, but you are using the outer dimensions, which is only 5 cu. ft"
lol...I just measure whatever the internal dimensions are...
Poll doesn't have an option for 1" board:confused:
edit: if someone asks about box size, I tell them the post sub and port internal displacement
Iusually give net dimensions unless they ask for gross. I built a ported box that was only about 3.5 cubes net but the entire box ended up being about 10 cubes total.
elephant box? haha
so this means my box now is only about 6. cu. ft 38x14x25 .6cu. ft of displ. total
snb778
blaugh!!!!
snb778
ex. Los Angeles, CA
delvryboy
