plz help when source is changed to disc subs cut out
It doesnt really matter what kind of wire you use for your remote as long as its single stranded. Is it ran on the same side as your RCAS?
What would happen if it's not single stranded? What would happen if the remote wire is on the same side as the RCAs?
Who's the e-thug now? All I have to say is learn some stuff but don't go around bragging if you get caught not knowing what you talk about. This site is suppose to be to learn and help people.
Um. I doubt it. I don't think your '94 thunderbird will make it all the way up here. Might want to top it off with anti-freeze first. You'd never make it into the hood anyways. dont kid yourself. Hangin in the slums of Mobile AL!
Im running an Alpine CDA-9884 and when I first turn the system on the subs and amp work and the radio is on. When I change the source to disc the subs/amp cut out... any suggestions? Thanks.
what kind of head unit? where are your RCAs ran? in a subwoofer outlet our rear speaker?
he already said what his deck is.
double check the remote wire color on the back of the deck make sure it is blue and white Alpine decks have a solid blue for antenna only and blue and white for remote amp turn on only they are not compatible with each other. when you switch to cd the amps completely turn off correct? if so you have the solid blue wire hooked up which is why they work on radio but not cd the antenna power is turning the amps on.
so you all know that is how to answer a ? all this bickering does him no good if you want to be e-thugs with each other do it in PM's or make a post for that. or better yet just go away.
mgrafton
mgrafton
Winnipeg, MB
SicAudio
