Plywood
Did you even go to the website? Its not plywood.
Read This
AdvanTech® is a family of engineered wood products specifically designed to provide more moisture resistance and stability than plywood. Built with an advanced resin technology system, AdvanTech high-performance panels provide superior performance to specialty plywood, OSB and other types of wood-based panels. AdvanTech products are engineered with higher strength and stiffness and greatly enhanced dimensional stability. US Patent 6,479,127.
Basic Uses:
Transportation
Modular Construction
Counter Tops
Furniture
Cabinets
and many other industrial applications
Sounds like it's a generic version of Hardi-Plank or similar products...
If you can find a way to chemically bond it and make it structurally rigid enough, it could work, although finishing it will be difficult.
Generic? No Way is this generic. Its used in million dollar homes. Like I said its 26 bucks a 4x8 piece. MDF is like at most 10 bucks a sheet
i think mdf is a little more than that. But to determine if it would be good for boxes, you would just have to find out if it is dense enough. Thats why people prefer mdf over anything else, because of its density.
Here in Knoxville,TN I get it for 7 dollars a sheet
then it would probably be a good product. But i dont know why you would want to pay that much if there is not REAL advantages to using it over mdf. I pay around 16 a sheet for the product we use on all our boxes. Its called Trupan. Its a lighter mdf. Little more pricy but the weight diff is incredible.
thehardknoxlife
thehardknoxlife
Knoxville, TN
johnson
