Pleze Help does this amp go good for these subs?
KB777
This is the amps stats
The LA370 is a 2 Channel 500 Watt MOSFET Amplifier.PRODUCT FEATURES: 2 x 200 Watts RMS @ 4 Ohms; 2 x 320 Watts RMS @ 2 Ohms; 2 x 1200 Watts Max Output; 1 x 2400 Watts Bridge Mode; Polished Chrome Finish w/Plexiglass Panel; Soft Turn On/Off Circuit; Variable Gain Control; Remote Turn On/Off; Hi/Low Level Inputs; Power On LED Indicator; Fully Adjustable Electronic Cross Over Network; Remote Control Bass Boost (0-18dB @ 60Hz); 2 Ohm Stereo Stable; Bridgeable Into 4 Ohms; MOSFET PWM Power Supplies; LED Protection Indicator; Frequency Response: 10-30 kHz; Power Supply Voltage: 14.4 VDC/NRG GD (10.5-16V); Maximum Current Draw: 50A; Dimensions: 11.5W'' x 2''H x 19''L.
And this is the subs stats (there will be 2 of them)
• 500 Watts Max / 250 Watts Rms
• Poly Cone / 1.5" kapton Voice Coil
• 80 oz Magnet Structure
• Mounting Depth 4.92"
• 20Hz - 2.5kHz
Brown Injected Polypropylene Cone
Specially Treated Black Rubber Edge Suspension
Bumped & Vented Motor Structure
1.5'' High Temperature Kapton Voice Coil
80 oz. Heavy Magnet Structure
250W RMS/500W Peak
Frequency Response: 25Hz-1KHz
SPL (1W/1M): 89dB
4 Ohm Impedance
Overall Diameter: 10.83''
Mounting Depth: 4.92''
Will this amp do good? I dont want to excede the rms for the subs cause they are a cheep brand but its all i can afford right now
KB777
KB777
home
undeadxsunshine
