Plexiglass question
black silicon or the sealant wont show because your going to paint the edges' underside.
you mean paint the first baffle overhang lip? -- (where the plexi will be sitting??) wouldn't it be easier to just use clear RTV silicone so you cant see it either way?
pan head sheet metal/wood screw with 100% silicone to seal it off
Well 100% silicone is not really an adhesive. I would like to use something that acts as an adhesive for the plastic to wood + a sealant. Like the RTV stuff
that why i said to seal...the sheet metal screws would hold it down against the silicone.
and 100% does adhere quite abit..ive worked in hardware for 5 years and like 100% over anything else out there, mostly because it seems like other silicones get old and hard and break off
does the 100% silicone just say "100%" on the bottle?
i would not use silicone or any type of glue , screw it down with gasket of sorts, if you want to remove it you can, if you silicone good luck getting it off. paint the back side of the plexi where the wood touches this way you wont see the wood or, make a trim panel to cover screws leaving a clean window.
Heres a vid of one I made. I used a thin white self stick gasket thing, used for doors windows, then predrilled oversized holes, and used flat head wood screws and finnish washers. Air tite and can still remove it if I have to.
pain free drugs fixtinhot
lasix medication
This drug is also used in combination with other pills of blood pressure to treat the problems of high blood pressure effectively.
buy furosemide
The chemical Furosemide works on the body by blocking the salt absorbing glands and the fluids within the kidney tubules.
http://www.foxspizzalasvegas.com/ - lasix cost
The diuretic effects of furesomide coming under Lasix are used most regularly to prevent the horses from bleeding when they are in a race.
bassman3
Box Designer & Fabricator
bassman3
Oregon
HSWaypeType
