PLEASE HELP!!
  • 4
WilliamK#24
I have an Alpine 143-BT head unit that has decided not to work. When I put power to it you can hear the eject mechanism inside making noise (CD eject mechanism). Nothing lights up on faceplate. How could you determine whether or not it is the faceplate or the actual head unit itself that is the problem?
915
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
897
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
WilliamK#24
WilliamK#24
Three Forks Montana
WilliamK#24
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
