please help
  • 2
97dakota
lovin Belize
2,052
Missouri
Ok, still somewhat new to all of this, I have an explod amp with two 10w0 jl subs. I have alow and a high pass filter I think they are called, so does that mean that I can run both my sub and my mids off of my amp. I know that it isn't ideal but I have limited funds. If I can where would I set the gains and can I even do this without a crossover. Thanks for any advice offered.
What model is your amp? Is it a 4 channel ? Let me know and we'll see what you can do //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah man that helps. You can run your subs and mids. Use the front channels for the mids. And the rear channels for the subs. Set the rear channels crossover to low pass, and the fronts to high pass. The easiest most effective way I know of setting gains is too find a piece of music you are real familiar with. Turn the gains all the way down. Then turn your head volume up to about 3/4 of max volume. Then slowly turn the gains up until you hear distortion in the music (popping, crackling, wierd distorted sound that you don't normally hear in the song, and such). Then back the gain down just a touch. And your good to go. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
993
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
97dakota
lovin Belize
97dakota
Missouri
97dakota
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
