Please help with Wiring Situation...
Surfed80
Alrighty I have 2 12's DVC dual 4ohm and each 12 is in its own sealed box. I just bought a T1001BD mono amp and its stable at 1ohm so I am going to wire each sub at 2ohms and then that would create a 1ohm load on the amp which would work perfectly but my question is from the wire comming from the amp do I splice it and add another wire to connect to the second box? I know how to wire the subs in the box like - to - and + to + and then to the box but I just dont see how the wire comming from the 1ch can conncect to 2 boxs? Any help, THANKS!
connect the negative terminals together then the positive ones together for one box. Then do the same with the second box. Now that thats done, connect the 2 negs together and the 2 pos together (twist them) then connect it to the amp. Thats 1 ohm. Check the wiring help for subs thread also. thats a big help
Surfed80
Surfed80
San Diego, Ca
swank
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
