Please help with infinity components
  • 3
Lmyb's
i Am wondering if stepping up and paying 100 more for the perfect 6.1 and getting the kappa 5 x 7 572.3cf would be good for sq or getting one set of the kappa 60.2 cs component and one set of the kappa 60.3cs. would be better. I am going for sq and want to stay with all infinity. Any help would be great cause i am getting different opions from my local shops. and is it better to get components in front and rear and have no 2 way speakers
but what about the rear do you think 5x7 will sound great i want about the best sq i can get. i really want kick panels but can't afford them
If you are after SQ primarily, omit the rear fill. It usually interferes with overall soundstage by pulling the music more to the rear- which is undesirable for any SQ application. Stick with the Perfect 6.1's up front and and power them with a quality amplifier and they should be all you need.
I have been competing in IASCA SQ competitions for quite a while, and have seldom seen many SQ systems with rear speakers that do well. They are expendable with a well tuned front stage.
take it easy,
-zane
O.K. skip the rear. i am getting dynomat or something along that lines for the front doors in my car. i have a 99 mercury cougar. also the guy was trying to sell me something the fit behind and around the speaker. it wasn't a baffler. i was wondering if you knew what this was and if it's ok to use. he said it would have no pink noise but it doesn;t look like it would help. and also any comment on a sq system would be helpfull. i dont want to compete but i would like a system that could almost.
thaks very much to any one who has replied
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
955
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Lmyb's
Lmyb's
houston,TX
Lmyb's
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
