Please help with a couple of questions
  • 4
502CEC
I am installing 2 Hifonics BRZ2400's and a American Bass fl1404. I have ordered a 275amp alt.(peaks @310) from Ohio Gen. The questions are about batteries, 1. Are extra batteries used mainly for when the car is off? I had planned on just buying 2 yellow top Optimas and putting back there (would that be sufficient?), however after buying everything else $ is getting low. So question 2. Would I be ok with just 1 for a couple of weeks or do I need to go ahead and squeeze out the $179 for the 2nd one.Thanks to all that reply
From what I know which is not a whole lot is the extra battery is to hold you around a voltage of about 13v or something close to that. I know there will be a senior member that will correct me but to my knowledge the extra battery is just to hold more power for when your amp really starts demanding power. I would get the battery but if you cant at the moment I am sure you can tone your amp down so it doesn't demand so much power since it would put a lot of strain on your alt. You can take my advice how you want, but I am new to car audio and am still learning but that is what my basic knowledge of a second battery is.
U will be fine with just 1 yellow top and a 275a alt of course a second would not hurt but it is something you could add down the rd. Does it do 275amps @ 3100rpms?? What does it do at idle 1000rpms??
We've had a couple of debates on this exact question recently in the forum, personally if you're trying to run that much power you're gonna need at LEAST a 2nd one, hell even 2 in the back with that much power would be good. There's multiple reasons, even with 1/0 wire running to the back you're still gonna get a decent bit of resistance off two 2400 watt amps trying to draw power across at 10-15' cable vs a 2-3' cable.
Batteries are gonna make big bass hits / drops not impact your overall voltage as much and give the alternator extra time (Even if it's just half a second) to react and start charging again, with the result being less power loss
Personally I'm running 2500 watts on a 135amp alt and 2 batteries (~80ah in the front, 105ah in the back), I will say if I was gonna push anymore power I'd definitely need to upgrade the alt, but to give you a picture, before dropping my 2nd battery in the back I had heavy dimming with my voltage dropping to ~12v, obviously not good. Dropped my battery in there with the expectation of upgrading my alternator soon after, and discovered I didn't even need to up the alt as now it typically doesn't drop below 14v.
I'd definitely squeeze out the extra cash, however if you want to save some money order a battery from Bad4Health (can PM him, he's on this forum), I cant remember but I'm pretty sure he was selling them for $120 (remanufactured I think?) Good batteries though, I ordered one from him and it's running in my trunk right now.
That and if you're running that much power it'd probably be a good idea to run 2 runs to the back (2 hot and 2 ground) of 1/0 or higher instead of 1 run.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
502CEC
502CEC
Frankfort KY
tpmeredith
