Please help! Polk MM6501 or Hertz ESK165 for the front?
Mokie
Hi, for all the gurus out there, please help out a NOOB, yours truly.
I'm currently running a set of Polk MM6501 crossed @ 400Hz (passive hpf) with a pair of Kicker SSMB6 in the doors of my 350z roadster with a Boston G510 44 behind my seat. For the rear, I'm using a pair of Polk EX365 coaxial (passive hpf @ 600Hz). The fronts are powered by an earthquake 600w.4. The rears are powered by (please don't laugh) a Power Acoustic 2 channel 180w RMS amp and the sub is powered by a Polk Momo C500.1.
The problem is that with the top down on the hwy, something is missing:( So I picked up a set of Hertz ESK165 to replace the rear coaxial.
My 1st question is, should I put the ESKs up front and the MMs in the rear or the other way around? I mainly listen to classic rock and metal and I prefer not to impose my music on others when I'm driving on the streets, but I must be able to enjoy Eddie's Little Guitar or Jeff Beck's People Get Ready (solo version) @ 80mph.
My second question is, would a pair of ambient tweeters help with the SQ when the top is down or is it just impossible to expect high quality sound in a convertible?
Any expert advice will be greatly appreciated!
I would keep the MM6501 in the front... why arn't you using the mids of the polk? I have heard the older momo's 6500, they compare to the hsk165!
what you need is a better amp on the fronts, provide it with a cleaner powered amp...
best would be to not have rear speakers... sell the esk165, kicker mids, polk coax, both the amps, and get a good/clean amp for the from mm's!
like stated above, are you using the tweets from the polk set and the kicker for your mid and not using the mid from the polk set at all?
if you are using the SSmb6 as your mid thats why you are "missing" so much. that speaker only plays 30hz-500hz. they really should only be used in a 3 way setup where you have a tweeter, midrange, and midbass. right now you are missing your midrange frequencies.
Im not sure what the earthquake does but I own the mmc6500 polk comps and they are rated 125rms but they didnt come alive until i gave them 150+ ( i say + becuase my birth sheet on my pdx150.4 says 165rms) been doing it safely for almost 2 years.
Thanks Asad. What would you recommend? Audison is out of my price range at the moment.
you didnt answer my question. if thats what you are doing thats the answer to your problem and you could save some cash.
SRim23, thanks for your reply. I'm using the entire MM set in the door (custom drilled holes) and the Kicker as Mid bass in the oem front door location. The sub is handling the frequencies below 100hz. The Kicker from ~100hz to 400hz, then the MM woofers above 400hz and the tweeters at whatever the MM crossovers are set at. The rears are for enhancement. The reason why I want separates in the back is because the coaxials are located directly behind the headrests of the seats and I was thinking of mounting the tweeters a few inches to the side so the headrests won't be blocking the higher frequencies. I then read somewhere that if the tweeters from the rear is too bright, it'll ruin the soundstage, which leads to my original question which set should I use for the front. I guess I really should be asking,"Which set should I be using for the back?"
heres the thing about rear speakers. generally speaking if imaged properly you should only hear the fronts when sitting in the front and the rears when sitting in the rear. thats why alot of people on go with a front component set because frankly most of us could care less about the passengers in the back seat. haha
i can say this from personal experience. my girlfriend and i have the same car. ive got an 05 civic, hers an 04 but same car just different years. she had front and rear comps i only had fronts. the only thing her having rear fill did was make her highs a little harsh. i disconnected the rears one day without telling her and she actually told me it sounded better, then i told her what i did. so sitting in front you shouldnt notice the rear anyways, definitely not when you put the top down.
your best option, like mentioned, would to get more power for the fronts. then maybe upgrade from there if the polks arent to your liking.
yeah... it would be smart to just get rid of your rear, the amps you have, and the kickers. Just keep the full polk mm set and get an amp that will make them what they are!
look into polk, diamond, sundown, ed, or even the audison srx amps... trust me once you put a clean amp sending at least 150 rms - you will love the polk's mm6501
Thanks dudes for your replies. I don't think the Earthquake amp is that bad. It's rms rated @ 130watts x4 in 4ohm and 220watts x4 in 2 ohm. It's pretty clean too... SNR 104db & THD is
Sorry for all these questions...since the few things I know about car audio, I pretty much read online, without real life experience. I'm hoping your expertise can save me some time, money & frustration.//content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
I'm using the Kicker SSM6, a midbass driver w/ frequency range fr 40Hz to 500Hz. So I'm using a bandpass 100Hz hpf and 400Hz lpf for them. I was told by the guy who built the bandpass to also put a hpf on the Polk woofers so there's no crossed frequency. Was that a wrong move?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
why did you xover them so high? i have my mids crossed at 80
if i recall the momo amp is made with those comps in mind. i think you can run them active off that amp without the passive xovers.
whether itll sound anybetter i dont know.
and dont be sorry, thats why were here.
Mokie
Mokie
City of Angels
Mokie
