What can i do to stop blowing my horn
ok, pop ur hood, i assume you have the horn mounted so it wont move around right? well while the horn is wired up and whatnot and playing, take a wire from the negative terminal of the horn and put the other side of the wire to the positive terminal on the battery...
a clothes hanger will work well too
any guess why they keep blowin i got them hook to da back of my deck
try this, this will jump the buffer gate and prevent thermal failure for the rest of its usage
but look i got to and one is connected to the other so both of them shud already be playin instead of just one correct?
do you think is it because i had bass playing?
(A):
Link doesn't work
(B):
Today i jus blew another one of my horn tweeters thats in the grill of my car and i dont know how i think its from the bass but i cant stop the bass from gettin to it can anyone help
//content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif
mmKaay.....
But to directly answer your question you'll need some method of keeping the lower frequencies, which tweeters obviously aren't designed to reproduce, from getting to your high-frequency drivers.
If there is no filtering available in the source unit or in the amplification then perhaps the use of some simple bass blockers might do the trick for you?
Handle 50w RMS, 6dB/octave slope, 2.8kHz cutoff
Same as above with a 5.6kHz cutoff
I HOPE THIS WORK
neek804
neek804
Richmond,Va
moh.vze.com
