Please help!... Noob Alert!
Jlandry287
I have no clue how to pick out an amp... I have 2 6x9's and 2 6.5"
They are both "true 4 ohms" with 2 ohm impedance. The peak power handling is:
•180w for the 6.5"
•300w for the 6x9
My question is, what size amp should I get and with how many channels?
Thanks for the help!
at 2 ohms the amp will give more power to the speakers ,but can get warm or even hot ,which is bad for some amps
You can also have a higher distortion factor at 2 Ohms vs 4 Ohms. If I'm not mistaken, a lot of the SQ competitors drive their speakers at the 4 Ohm load because of that reason. I could be wrong on that one though.
you are correct sir ,didn't want to confuse him with the thd factors ,or distortion levels
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Jlandry287
Jlandry287
Lake Charles, LA
mylows10
