Please help!... Noob Alert!
Jlandry287
I have no clue how to pick out an amp... I have 2 6x9's and 2 6.5"
They are both "true 4 ohms" with 2 ohm impedance. The peak power handling is:
•180w for the 6.5"
•300w for the 6x9
My question is, what size amp should I get and with how many channels?
Thanks for the help!
at 2 ohms the amp will give more power to the speakers ,but can get warm or even hot ,which is bad for some amps
You can also have a higher distortion factor at 2 Ohms vs 4 Ohms. If I'm not mistaken, a lot of the SQ competitors drive their speakers at the 4 Ohm load because of that reason. I could be wrong on that one though.
you are correct sir ,didn't want to confuse him with the thd factors ,or distortion levels
Jlandry287
Jlandry287
Lake Charles, LA
mylows10
