mylilpeterbilt
Hello everyone! I have several questions and am quite new to car audio so I am looking for some help. I have a 20ft race boat that I am going to put a system into. I just bought a pair of RE XXX 6.5 components and already have a 12" type R. My questions are about designing a box for the sub and also for the RE's. There really isn't any space limitations for the sub box as it will be going up under the front of the boat but I was wondering if there needed to be design changes because it isn't going in an enclosed trunk or cab of a vehicle.
Now for the RE 6.5xxx's what type of box would suit those best? They are getting some type of enclosure built for them either way so would it be beneficial to build a mini ported box for those as well or is that only for subs? Can both 6.5's be mounted into the same box with each other or do they need to be separated? Where is the best place for the tweeters to mount? I plan to have the 6.5s in a box or 2 boxes up under the front as well to try to protect them from spilled drinks!
Sorry for so many questions but I've never built a system before and I would obviously like to do it correctly the first time! Most of the music will be rap type stuff and I would like to be able to hear it outside of the boat of course. Will a 4channel amp work for my situation if this is all I plan to run? I don't have an amp chosen yet or a HU so if any of that will play a part please advise. I don't plan on running a marine amp as it will be in a nice safe place. I will put a picture of the boat and I plan to put everything up where the driver and passengers feet go. It is completely open under there all the way to the front if that matters where speakers should be placed.
Thank you again so much for your help
