please help me upgrade my subs
markak134
Banned
598
7
pa
i am currently using 2 kicker comp 12s in my car and they are just not cutting im looking for a more clean bass with more boom the kicker comps are just like anoying bass
i have $220 to spend and i would like to get a pair for that much
this is my amp
Amazon.com: Kenwood KAC-9104D 1800-Watt Max Power 1 ohm Capability Class D Mono Power Amplifier with Variable LPF: Electronics
i was thinking about these i dont know
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
you mine as well save up 20 more bucks and get an fi Q 12 for 240 shipped. Well known SQL driver. ficaraudio.com. Sub 1000 rms so amp will work great to power it with 900 rms
why the hell would you reccoemd a kicker sub??? the sq on those things are just UNNACCEPTABLE.
Actually that's not true if a sub is on clean power and in a good box then it can sound good
i have heard many kickers that sounded great.....
these are the first subs i ever bought and i hate them once you turn it up too loud it all goes to shit
Amp may be clipping the power to the subs and making them sound bad or it could be your box, there is a lot that can cause things to sound bad.....
is the amp too powerful for them?
and im pretty sure the box is good
i had 4 of them but then they just like started to **** maybe the amp is bad for them so i threw out one box because i was using 2 and the bad box broke so im just using 2 subwoofer now in the good box maybe i should just keep the 4 comps and get new boxes i dont know maybe its the amp
i had them all 4 at 2 ohms it would hit great and sound good but the amp cut out the bass at high volumes them i put it on 4 ohms and it will play now without the amp getting hot but it sounds real shitty
2 12 Comps are rated at only 300rms together.....Considering your amp pushes 500rms at 4 ohm, and 900rms at 2 ohm, I would say they are being over powered no matter how they are wired unless your amp is turned WAY down...
id go with 2 12" cvx...ive got them in 10s and they POUND...no shitty sq or anything...the cvx are WAY better overall compared to the cvrs...or u could go with a single 12" or 15" lvl 3 or even toss in $55 more and get the lvl 4 12...u cant really go wrong with either and theyre close to ur price range
markak134
Banned
markak134
pa
markak134
