OP
InfinitySound10
- Thread Starter
- #16
Lesson learned....I just adjusted the LPF to 80hz, killed the Bass Boost, put the xover to LPF....With the gain half way, at a loud volume I can feel only a slight vibration on the subs, they are getting something, but its nothing significant.No but if you keep it that way, you will most likely end up with some paperweights
Can you explain how I can check the phase?
I was looking on crutchfield and it basically said to switch the + and -, and it it sounds better use it...this sounds risky to me, so I want to consult you guys before going any further.
Thanks much
