Please help me tune my sub amplifier
No but if you keep it that way, you will most likely end up with some paperweights
Lesson learned....I just adjusted the LPF to 80hz, killed the Bass Boost, put the xover to LPF....With the gain half way, at a loud volume I can feel only a slight vibration on the subs, they are getting something, but its nothing significant.
Can you explain how I can check the phase?
I was looking on crutchfield and it basically said to switch the + and -, and it it sounds better use it...this sounds risky to me, so I want to consult you guys before going any further.
Thanks much
Yea so I was just moving the amp again to adjust the gain levels, and the power AND ground cables popped out of their U attachent things which were covered in tape....Im guessing one if not both of them were loose, thus explaining the low power levels to the amp:eek:
Im gonna take everything out tomorow, wire it properly, mount the amp properly, and report back.....dont want to waste your guys time with my lazyness....im just so ****ed excited to piss off old people:up2somet:
Thanks a lot guys
InfinitySound10
InfinitySound10
New Jersey
InfinitySound10
