Please help me on GF's install
Orionpower
Hey im running a 12w3v2 12 in a ported box tuned to jl specs with diagrams from site, an infinity 310 amp with a stock headunit. I have a hi-lo converter and im not exactly sure which wires go to which terminal on the converter? does anyone have a diagram for this? I also need to know where I run the remote, something to do with ignition if I remember correctly. Excuse my ignorance for I have never installed an amp with a stock head unit and help me out, thanks.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Welcome to the forum my brother man. Depends on what kind of LOC but most just connect pos and neg from both right and left. Most use the rear channels of the head unit. You can either tap the wires in the trunk under the rear deck if there are speakers back there, or behind the head unit itself which would require you to run the rca's from behid the head unit a well. THe LOC May or may not have a remote wire built into it, if it does you will need to connect it to a switch 12v source. If it doesn't you can run the remote wire from a switched 12v source. Meaning it gets power when the ignition is on. And doesn't when the ignition is off. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks for the warm welcoming ramos, and the help. I appreciate it. This was the gf's x-mas gift. Once I get some cash flow im gonna get a new AA driver to run off my orion275g4
Orionpower
Orionpower
Bay city, MI
ramos
