Please help me fast, i am leaving in 20 minutes
  • 2
buchel
Veteran n00b
I need to know what size i should make the box for my perfect 12.1's, it is going to be a sealed box, with chambers for each sub, wat size should each sub get? i have been told .6 cubic feet is good? please let me know, as i am going to make the box in 20 min or so...
Thanks,
~ Kyle ~
I'm not sure what the proper size is, but you should really take your time and plan out your box instead of just rushing to make one real fast.
~JB
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
buchel
Veteran n00b
buchel
Ontario, Canada
-jb-
    May 24, 2024
    May 23, 2024
