PLEASE HELP!!! I have a KENWOOD dnn770hd radio for my car......
I have a KENWOOD DNN770HD car stereo. i wrecked my last car that it was in and i bought another of the same car. I reinstalled it and it remembered my last account. as it walks me through the simple steps (date, time, etc) it then takes me to the "user" screen. it asks if i want to sign in under my name or as a guest. i click on my name then it prompts me for a password. I click on the password box and a curser appears but it doesnt allow me to type. instead, it gives me a message "PARK OFF". what is happening?? this particular model does not have a function that prevents me from watching dvds while i drive so I know that is not the problem. thank you!!!
believe it or not, this one particular model does not have a "parking brake" wire. i bought it specifically for that reason. it was first installed, "professionally" in my 2003 monte. they screwed it up and i had to rewire it. it got wrecked and now i put it in a 2002 monte. there is definetly no "parking brake" wire.
The ones crutchfield sells seem to
And the manual states certain things can only be done with the parking brake on
http://manual.kenwood.com/ce/im365/NorthAmerica/English(en)/010_SettingUp.html
wth does a parking brake have to do wth car audio?!?!
Its a safety feature. People were watching DVD's while driving so car manufacturers started putting them in and car audio companies started adding features to prevent that.
Ah makes sense . Thanks for not being a jackass about a reply....as some other un-named people might have.
Driving distractions 101.....put the phone down and drive....quit watching dvd's and drive!!
i dont understand if, it was the parking brake case, why wouldnt it allow me to simply "sign in" under my name, while the car is parked or running, and not allow me to "type" my password in. when i try to the the curser on to type, it appears then the little message "PARK OFF" briefly appears. again, this model does not have the parking break wire. i just downloaded the instructions and it shows a diagram of the 990hd model, with a parking break wire.
I have a seat Leon 2010 1.6tdi it’s fitted with a seat unit that won’t load sd card internal error so bought the above stereo to upgrade and a...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
952
KENNY GUIDO
KENNY GUIDO
MASSAPEQUA, ny
kcr357
    May 16, 2024
    May 16, 2024
