Please can you help me
fire919
I don't want to do this wrong. Ok, so i have
2 •12" Dual 4 ohm Champion Series Subwoofer
1 •Kenwood KAC-9105D
I want the most bang obviously, so i guess very simply i want to know is how do i achieve this?
Below is an image of the amplifier, It has 2 + and 2 -.
Note: I didn't put a picture of the subwoofer bcuz i am sure your all experts and know extactly how a Dual coil woofer looks.
Hook up amplifier. Wire subs to 1 ohm. Connect subs to amplifier. Set gain and filters. Done. If you can't do that, then you have no business hooking anything up. So go read up on anything I said that you didn't understand.
yes the amp will handle 1 ohm and just to respond to daboyfrumdabx i understand evrything you said but what do i do with the other + and - that will be left over. O yweah thanks for quick response
I tried to add a link for the amplifier specs but i guess things changed since i was here last anyway this is what i think is important
•RMS Power Rating:
◦4 ohms: 500 watts x 1 chan.
◦2 ohms: 900 watts x 1 chan.
◦1 ohm: >900 watts x 1 chan
Umm. Wouldnt run this amp at 1 ohm. It says its 1 ohm stable but it regulates the power to 900, which it puts out at two. You can try it. But you wont gain any power from it and I'd be scared it'd go poof. Mine did just runnin it at 2.
Just curious , what will it mean if i wire each sub @ 2-ohms and connect to the 2 pairs of outputs.
That would yield the same result as wiring the pair to 1 ohm then to the amp. I typically wire the pair to 1 ohm because that get's done inside the box, then I just have to use one terminal cup. If I were using a prefab box with separate chambers that had 2 terminal cups, then I would wire each to 2 ohms, then each to the amp.
fire919
fire919
the bronx,NY
fire919
