Play Music Play!!!!
nawgee
hey guys!
my sound system keeps screwing up on me //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
as soons as I pop my deck in and turn my stereo up the slightest (not talking about booming loud, just enough so I can hear sound), my amplifier shuts off. when i bring my sit up to look at my voltage, it reads like 7.6. i have done the big three and have seen my volts as high as 14.3. it just started a couple of days ago, and i have had the same system in my car for about 9months now. has anyone had this sort of problem. also does anyone know where i could get an HO alt for a 2003 lancer es
btw this problem has happened before, but whenever i blasted my music...i've done the big three and it stopped for a little while...now it seems to happen when my volume is low. //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
are you testing at the battery or amp when reading 7 volts?if its at the amp check your grounds.
well actually im going by what it reads on my cap which is right next to my amp....should i be testing it elsewhere??
Remove the cap and try again? Get a DMM and check the voltage at your front battery with car off and then car on... let us know.
nawgee
nawgee
Valencia
Bun-Bun
NorthFramingham
    Jun 30, 2026
