Does my system require a SEPARATE BATTERY?
Any alt/single bat combo would have problems keeping up with those initial power demand from an amp that powerful. A second battery will definitely help smooth the voltage drops before the alt's reg kicks in to supply the power demand.
An HC600 is too small for that power - it would choak on the high demand and you'd still see bad voltage drops. He should go with something the size of at least HC2000.
i would put a powermaster d925 near the amp, and upgrade ur big 3 or even just the ground wires under the hood. i wasnt able to get to the alt. so me and jmanpc just did the ground wires and it helped me out. next for me to get put a d5100 under the hood. stock battery is only like 300a
guitarman626
Guitarman626
guitarman626
Lubbock, TX
skmfkr
