planet audio bb 1250.1
ajspellm
i have a planet audio bb 1250.1 and it worked great for about a month or so bu then i was playing a song and it smelled like that amp was about to catch on fire and then it went into protect mode. The amp hasnt worked the same since that happened. it was wired at 1 ohm at the time. so now i am trying to see if its the amp that is blown or the sub. so i rewired the sub to 4 ohms and i am trying to start it but all i am getting is a wining noise from the amp. the wining noise is of the music i am playing though. so i assume its the amp that is blown right? also i have a dual 2 ohm type r that i am using with this sub. if i have to buy another new amp, what would you recommend? do you think the sub could have possibly been damaged because of the amp? i am pretty sure i had it wired right but i have always had problems with blowing amps. also i looked on the inside of the amp and there is a lot of hot glue on the inside of it. is that supposed to be there?
thanks
ajspellm
ajspellm
Omaha, NE
ajspellm
