I love everybody's comparisons to try to justify their position, and explain it to others that aren't seeing it their way... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif "For Example, if you take a car with 2 bars... "For example, if you put a Hot Wheels car in a bathtub full of Pistachio pudding... "For example, let's say you take a room full of nuns having an orgy, but said room is on wheels..."
Jebus you guys. The plane will fly. Remember Top Gun? When they take off (in the opposite direction the ship is heading, I might add... SORT OF LIKE A ****ING TREADMILL), what do they do to propel the plane? Stop the ship??? Course not. They raise that thing behind the engines, so that thrust is enhanced and it moves the planes forward at a rapid rate. Why is this, you might wonder? Because planes operate off of THRUST. Thrust is generated by their engines and pushes against the wind, or air, or some object placed behind the engines, or what have you. So just because the plane is on the treadmill, doesn't mean that when the engines kick on, that all of the sudden the concept of thrust is out the window and it has to overcome the speed of the treadmill. Because it uses AIR. Not the friction between the tires and the treadmill. Picture the plane not moving at all, engines off, rolling backwards on the treadmill as it sits, stationary in relation to the treadmill, and moving backwards in relation to the ground. As soon as the engines turn on, the plane will propel forward, because of THRUST. It doesn't have to get its wheels up to speed to overcome the backward motion of the treadmill first.
