well if the conveyor belt surface has enough friction to keep the wheels in place (relative to the conveyor belt) while the engine is theoretically moving the plane forward at the same speed the conveyor belt is moving backward then it still would not move correct?The wheels are independent of the plane you r-tards... they are not drive wheels... and have nothing to do with the lift of the plane...
nG
Such feeble little minds...well if the conveyor belt surface has enough friction to keep the wheels in place (relative to the conveyor belt) while the engine is theoretically moving the plane forward at the same speed the conveyor belt is moving backward then it still would not move correct?
It's like when your on a boat thats going one way while your walking the other way. Your moving, but your staying in the same spot.
I don't think they could get the conveyer belt to move that fast. But the ball couldn't move as fast because the instant you let it go it is subject to wind, friction, bounce, and probably other factors I have no idea of what they are.so for those saying that it wont cause there is no lift....then you would also say that if you stopped the conveyor belt after it was moving to a speed equivalent of what a plane would usually take off....the plane should almost instantly be at full speed and in a perfect situation would take off instantly without having to move forward? like if you hold a ball in a car its speed relative to you is 0 but if you drop it the instant it hits the stationary ground it will try to accelerate to the speed of the car it was previously in?
REEEEEEETARD.The plane can not lift off unless there is air moving past the wings. The wheels can move all **** day but if there is not enough wind speed to force the wings upward the plane will sit on the ground.
On the other end of the spectrum:
If you tied the plane to a pole and placed a huge, high speed fan in front of it the plane would lift off, yet not move forward, like a kite.
This is why they use a wind tunnel to test down force on race cars and not a dynomometer. //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
yah your right. I kept thinking that the wheels would have the same ammount of thrust as the engine would (when they are on a conveyor belt).Give up Konechiwa, it was already been discussed dozens of times, the friction caused by the conveyor belt spinning the wheels twice as fast is nothing compared to the thrust generated by the plane itself...
