pioneer stoppped working
check with a meter that ur getting 12 volts from the harness of the radio. just becuase the fuses are not blown doesn't mean that the radio is getting 12 volts. let me know when u find out, good luck.
Check ALL the fuses. Even the ones under the hood. Meter the harness. First check for 12v constant, then check switched. Try wiggling the harness around and see if the radio cuts on. Check the ground.
ggreenjohny
ggreenjohny
south carolina
ggreenjohny
