Sold PIONEER PREMIERE TS-W5000SPL FS/FT ($300 shipped FIRM)
misfit138
a whole new type of aids
1. Product:
Pioneer Premier TS-W5000 SPL.
2. Condition:
9.5/10 cosmetic
10/10 function
3. Specs:
■Interlaced Carbon Fiber Reinforced IMPP Cone Woofer
■Wide-Roll, Woven Aramid Fiber Radial Rubber Surround
■Overhung Surround Design
■Ceramic-Coated Voice Coil Wire
■Dual 3", High Inductance, 4-Layer, Long Voice Coil (2 x 4ohm)
■7-Slit Glass Imide Voice Coil Bobbin
■Precision Double Conex Damper with Damper Rings
■Projected Pole Yoke with Vented Pole
■Aerodynamic Magnetic Gap (ADMG) Design
■Massive (320 oz.) Triple Stacked Magnets
■Thick 1.2" (30mm) Top Plate
■Aluminum Die-Cast One-Piece Rigid Chassis
■8-Gauge Wire Terminal Specifications
■5,000 Watts Max. Music Power
■2,000 Watts Nominal Power Handling
■Frequency Response: 18 - 2kHz
■Sensitivity: 88dB (1W/1m)
4. Pics:
$300 Shipped (FIRM!)
THIS SUB HAS NEVER SEEN MORE THAN 1,000 WATTS OF POWER!
I don't know what to say about the enclosure, as it's not mine. This sale is for the sub ONLY...
What exactly is the difference....other than the dustcap? Impedance?
the coil in the 5102 is 6 layer the 5000 is 4 layer,mine has a thicker heavier dustcap so that means the coil in mine is heavier and the dustcaf is too which means the t/s specs are different.and are rated for more power.also the one i have is blown,i want a blown one so i can recone a matching pair
the coil in the 5102 is 6 layer the 5000 is 4 layer,mine has a thicker heavier dustcap so that means the coil in mine is heavier and the dustcaf is too which means the t/s specs are different.also the one i have is blown,i want a blown one so i can recone a matching pair
Gotcha.
I'm not an expert on these subs. I really wish I could play around with this one for awhile, but I just can't afford it...
misfit138
misfit138
Williamson, WV
misfit138
