Sold PIONEER PREMIERE TS-W5000SPL FS/FT ($300 shipped FIRM)
misfit138
a whole new type of aids
1. Product:
Pioneer Premier TS-W5000 SPL.
2. Condition:
9.5/10 cosmetic
10/10 function
3. Specs:
■Interlaced Carbon Fiber Reinforced IMPP Cone Woofer
■Wide-Roll, Woven Aramid Fiber Radial Rubber Surround
■Overhung Surround Design
■Ceramic-Coated Voice Coil Wire
■Dual 3", High Inductance, 4-Layer, Long Voice Coil (2 x 4ohm)
■7-Slit Glass Imide Voice Coil Bobbin
■Precision Double Conex Damper with Damper Rings
■Projected Pole Yoke with Vented Pole
■Aerodynamic Magnetic Gap (ADMG) Design
■Massive (320 oz.) Triple Stacked Magnets
■Thick 1.2" (30mm) Top Plate
■Aluminum Die-Cast One-Piece Rigid Chassis
■8-Gauge Wire Terminal Specifications
■5,000 Watts Max. Music Power
■2,000 Watts Nominal Power Handling
■Frequency Response: 18 - 2kHz
■Sensitivity: 88dB (1W/1m)
4. Pics:
$300 Shipped (FIRM!)
THIS SUB HAS NEVER SEEN MORE THAN 1,000 WATTS OF POWER!
I don't know what to say about the enclosure, as it's not mine. This sale is for the sub ONLY...
yeah im remembering scoping these subs out awhile back.....if i recall they cost about the same as a dd9500g brand new......did you have it installed?
It is an expensive sub. And no, I haven't used it. The guy I got it from didn't really use it either. He was using a p.o.s. amp...
Of which are subsequently selling for $450 used right now...And this is only $300! Even if the DD cost the same, I would rather have this sub //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
misfit138
misfit138
Williamson, WV
misfit138
